Hi there,
I've just got myself a WinTVFM capture card. It's all installed and seems to be functioning fine when I've done a trial capture from the TV antenna. But the main reason I bought it was to capture from video, and I need a little help figuring out which lead(s) I need to do this.
I mostly plan on capturing from my camcorder. The camcorder has what I assume is a standard camcorder transfer lead with it. The camcorder end has a round plug with 8 pins inside. Sorry, don't know the proper name for this - photo of it here:
Sorry it's a bit blurred, but you should be able to tell what it is.
The other end of the transfer lead is a SCART plug.
The video in socket on the capture card is an S-VIDEO socket.
So, could someone please advise me which lead/combination of leads/sockets I'll need to connect my camcorder to my capture card?
Is there one lead that can go direct from the 8 pin camcorder socket to S-VIDEO, or will I need to connect the camcorder to SCART lead to a double female SCART and then have a SCART to S-VIDEO going from the double female SCART to the capture card?
Hope I've described that clearly.
Also, I understand that S-VIDEO sockets only bring in the picture and not the sound? So I assume any lead I have going into the S-VIDEO socket should also have an audio cable built in that will go into the "line in" socket on the capture card, to take the sound into the card?
If you could also let me know the best place to get the lead(s) I need, I'd be most grateful.
Please keep your answers simple, I'm brand new to capturing.![]()
"I don't mean to sound cold or cruel or vicious - but I am, so that's the way it comes out." - Bill Hicks
I've never seen one of those 8=pin leads before - sorry can't help.
You're correct in assuming you'll need a separate audio cable to go into your line out though.
Also, if you want recommendations about where to buy cables, it might be an idea to tell us what continent you live on - and maybe some even more specific details! :P
cheers,
mcdruid. -
Whoops!Originally Posted by theDruid
I'm in England.
"I don't mean to sound cold or cruel or vicious - but I am, so that's the way it comes out." - Bill Hicks -
Should have guessed from the Spurs logo I suppose!
Maplin is probably going to be your best bet for cables - if nobody on here can advise you what you need, you could try just taking the cable you've got into a Maplin store and asking their advice.
cheers,
mcdruid. -
Cheers mate, I'll bear that in mind if I get no more replies. But I would like some more. Anyone? Anyone? Bueller?Originally Posted by theDruid
Went to my local Maplin, they sorted me right out with a combination of leads/connectors to enable me to connect my camcorder with the obscure socket to my capture card.Originally Posted by theDruid
Everything working fine so far, my first few efforts aren't bad, but I'm sure they'll improve in time as I learn more.
Many thanks for your suggestion, which sorted me right out.
Now I just have to learn how to compress/reduce in size the rather large files my card is depositing on my H/D.
Capturing hardware advice
By johnestan in forum Capturing and VCRReplies: 0Last Post: 24th Sep 2011, 20:13 -
Need advice on best capturing solution
By vitalic in forum Capturing and VCRReplies: 22Last Post: 15th Feb 2011, 14:11 -
Your Solutions and Advice for Capturing
By SixFiftyThree in forum Capturing and VCRReplies: 2Last Post: 12th Feb 2011, 01:19 -
Connecting Freeview to Panasonic DMR-HS2 Advice Required!
By wilberfork in forum DVD & Blu-ray RecordersReplies: 2Last Post: 21st Aug 2008, 08:23 -
Need advice about capturing VHS
By jimlong in forum Capturing and VCRReplies: 5Last Post: 1st Jun 2008, 03:11
