I have read all the posts regarding this, and didn't find anything, so I started a new thread, and call for help. I have been using TMPGenc for ages, making vcds. My old system was an AMD K6 with Win98. It crashed, and I built a new one with an Athlon, gig of Ram, a dvd burner, and more importantly WinXP. When I first got everything together, I couldn't get TMPGEnc to work, and then I messed with the environmental settings, changing priorities and such, and it worked fine. I reinstalled WinXP because of different problems, and now, no matter what I do, TMPGenc doesn't work with the Pinnacle MJPEG codec. Nothing really changed. Does anyone have any ideas?? Should I reinstall the Pinnacle software? I installed a codec pack for divx and such, but that has nothing to do with the Pinnacle codec.
You do not mention if you have another non pinnacle MJPEG codec installed. Try to open your captures with VirtualDub as it has a built in MJPEG codec. If that works get a copy of the picvideo, morgan multimedia or mainconcept mjpeg codec and install it. Tmpegenc should see your captures then.
I do not have another mjpeg codec installed, but I will try that. Regardless, it worked before, so that is what is puzzling me.
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 04:03 -
Software for S-video output on Pinnacle DC10 plus card(XP)
By Eightbitgnosis in forum Software PlayingReplies: 2Last Post: 30th Jan 2010, 10:33 -
Miro DC10 /DC10+ and fedora
By bmw524 in forum LinuxReplies: 2Last Post: 14th Nov 2008, 15:54 -
Pinnacle AV/DV2 or DC10+B miserable performance
By cybertheque in forum Capturing and VCRReplies: 1Last Post: 17th Sep 2008, 22:44 -
Pinnacle DC10 Plus on Windows XP
By Paulsa in forum Capturing and VCRReplies: 0Last Post: 3rd Apr 2008, 11:02
