I bought a new HP dvd writer 300n and I backed-up a few dvd's to dvd+rw, and now that I think I have the meathod down with DVD X COPY, I want to copy the dvd+rw's to dvd+r's. I have tried and I keep getting an error and I have used Nero 6 and Recordnow max. I am hoping that there is a prog out there to make my life a lil easier.
HP Pavilion
Celeron 2.0ghz
256 ram
60 gig HD
1 dvd reader/cd burner
1 HP dvd writer
THAN YOU IN ADVANCE!
If at first you don't succeed; call it version 1.0
First of all if your source disc is a dvdrw them most likely it isnt encypted so why use xcopy? Anyway, if your sure the dvdrw is completely working then just rip it to your hard drive and then burn it with any burning program. nero should work fine. If you can be more specific on what error you are getting and when you are getting it then you may get more responses. we dont know if you are ripping it the right way or if you are using nero correctly.. Like maybe you have nero set on cd and not dvd, or whatever other possibility there is.
TY for the response..I will be more specific. I took dvd x copy and burned my dvd+rw's....that went fine. When I try to copy them I get an error although I cant remember what it is...I can try to copy dvd+rw to dvd+r with nero 6 using the dvd copy feature with failure. I have tried to rip the disk just by making a new folder on my desktop and inserting the disk and copy and pasting the files to that folder (from the dvd+rw to the HD) and then burn from that folder to the dvd+r. I will try it again and write down the error I was getting. But I know it will write to the dvd+r's to like 98% then I get the error. TY for the help
If at first you don't succeed; call it version 1.0 -
in other words...I take a original dvd I want to back up....copy that to a dvd+rw...then try to copy the dvd+rw to dvd+r
SPIDERMAN....Thank you sooooo much for yor help...did what you said and I had NO problems...thanks a million...this site rules!!!
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 18:35 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 13:34 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 09:59
