I have been using Vdub-MP3 to check for bad frames. From the resultant badframes.log files I remove the bad frames but I go 1 frames foreard and 1 frame back from the badframes.
The guides say I should move forward to the next key frame and also back to the previous key frame. This method will remove some good frames also.
1) Why should I lose good frames by moving to key frames
2) If i don't use the key frames will I lose audio sync?
Frames other than Keyframes aren't all there. If you remove a frame
you should remove all frames after it up to and not including
the next keyframe. Frames after a Keyframe need information
from the previous frame to be decoded. If you delete a frame,
the next frames after it can't be decoded until a new Keyframe shows up.
Edit: That doesn't apply if you save as something without keyframes
or frameserve it out.
Please can someone help with frame-by-frame video editing?
By likasombodee in forum EditingReplies: 2Last Post: 6th Mar 2011, 19:06 -
POSSIBLE? Captured 8mm Movie Frame by Frame Editing
By PLW in forum Newbie / General discussionsReplies: 15Last Post: 21st Jan 2009, 13:21 -
Editing Text Frame By Frame In After Effects
By sk8_aholic in forum EditingReplies: 4Last Post: 18th Nov 2008, 18:27 -
Frame by Frame Editing / Painting
By abvision in forum EditingReplies: 6Last Post: 2nd May 2008, 11:34 -
Suggest a video editor for frame-by-frame editing
By ontherocks in forum Newbie / General discussionsReplies: 14Last Post: 24th Apr 2008, 09:36
