Is playing my VCD in Black and White.
DOes the same with SVCDs.
Why would this be?
I've searched and pound this thread
https://www.videohelp.com/dvdplayers.php?DVDnameid=1114&Search=Search&#comments
but doesn't help too much!
Clark,
This unit is a UK model designed to playback PAL discs and not NTSC. You may want to check your discs, you will probably find out they are in NTSC format (29.97 fps). This is common for Sony units, while many cheaper players out there will play discs and convert to any format (PAL or NTSC), I believe all the Sony's are designed to only play the discs from the area they are sold in. On top of that, still another reason not to buy Sony DVD players - no region hacks, you have to add a chip to play discs from outside the region the unit was designed for.
This note is from your owner's manual:
Ethernet (n): something used to catch the etherbunny -
I guess that means you figured out what the problem was...
Sony dvp-sr100
By deyangg in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Oct 2011, 04:54 -
My Sony DVD player SONY DVP- NS718 H
By samyer in forum Newbie / General discussionsReplies: 1Last Post: 3rd Feb 2010, 00:56 -
Sony DVP-FX720
By haidee in forum Portable VideoReplies: 0Last Post: 3rd Jan 2009, 09:11 -
HELP !!! Please !! Sony DVP-S7700
By adamsj13 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Oct 2007, 05:04 -
Unlock for Sony DVP NS305, without a numbered remote or palmpilot/PC?
By Jessminka in forum DVD & Blu-ray PlayersReplies: 1Last Post: 20th Sep 2007, 12:46
