for anyone running windows 2000 that is noticing that it takes like 5-7 minutes for it to boot... if you have easy cd creator installed, uninstall it. boot time will only be like 2-3 minutes!
dont know if this is common knowledge or not, but i figured i would share my discovery.
Results 1 to 1 of 1
Can I re-install older dual-boot OS and still have the dual-boot work?
By jeanpave in forum ComputerReplies: 8Last Post: 3rd Dec 2011, 02:06 -
Is there easy way to create Win2k boot disk with command prompt available?
By bevills1 in forum ComputerReplies: 9Last Post: 10th Apr 2008, 12:25 -
Need advice for takin snippet6s from several DVDs and editting a clip
By scottb721 in forum EditingReplies: 4Last Post: 28th Sep 2007, 20:27 -
Why does it last forever?
By NormaJ in forum Newbie / General discussionsReplies: 2Last Post: 4th Jul 2007, 11:28 -
DV capture taking forever
By Kihon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 16th Jun 2007, 14:08
