Guys and gals,
The title says it all. I have encoded a downloaded AVI using TMPGEnc Plus into an SVCD. I then used the header trick to change the header to MPEG1 non-compliant.
I burned the file using Nero (ignoring it's compliance warning).
It plays on my Sony DVD but I hear "noise" and it clips the sound. Also the video is slightly jerky.
Any thoughts?
Get a real DVD Player. Sorry, sounds callous, but the 'VCD Header Trick' is just that, a trick. If you player doesn't support SVCD, then it's inadequate for you needs.
Or you can buy a DVDRW to backup your own DVD's. Converting 1960's educational videos seems like a lot of work for having to use the header trick.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I checked the compatability and my SONY DAV-S800 can play SVCDs using the header trick.
Trick PSP video
By jntaylor63 in forum Video ConversionReplies: 0Last Post: 4th Aug 2011, 10:42 -
Export Video Header
By BRotondi in forum Newbie / General discussionsReplies: 3Last Post: 18th Jan 2011, 16:35 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 20:40 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 01:57 -
Is there some trick to putting in a video card?
By videobread in forum ComputerReplies: 12Last Post: 21st Jun 2007, 22:07
