  1. i just copied a vcd today, buy moving the dat file to the computer and use vcd gear to change it to mpg, then used nero to burn as vcd...
    and when i watched it on tv, it got those little squares, green squares on it...why's that?? is copied from the origial vcd, and in the vcd gear, i already chose fix mpg error blocks, and how come is still like this??
    can anyone help??
    or is there another way to copy vcds so it won't get those little squares box??
    thank you very mcuh~
  2. Why don't you just do a disk copy with NERO. I use the backup function of CDRWIN and haven't had any problems playing the copy on my DVD player.
  3. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    so you mean use nero or CDRWIN?? if i use nero, i just choose cd-copy function? do i need to do any settings?? and when i play it in normal vcd player it won't have those green boxes??
  4. You can use either.
    In fact, you can use almost any CD burning proggy that supports the copying of CDs.
    Regards.
    Michael Tam
    w: Morsels of Evidence
