I've been using DVDShrink which is almost perfect software. Only major problem is the video quality when encoding has to be performed.
I haven't tried yet any other software (for example DVDFab, CloneDVD, DVD2one) which also seem to has the possibility to use original menus and structure. I would like to know if one of these software has better quality with video encoding? Or is there still some software missing from my list that has good quality and possibility to use original menus?
Is there this kind of software which is able to use external encoder such as TMPGEnc / CCE?
Thanks in advance!
Results 1 to 11 of 11
It's not free, but I use INTERVIDEO DVDCOPY v1.2.
It can backup a DVD-9 DVD to a DVD-5 DVD-/+R without loss of quality. I have backed up numerous DVD's with this program and haven't seen any loss of quality. Oh yea, when I backup, I backup the WHOLE DVD, not just the movie. This program can also convert DVD to VCD, SVCD, DivX, and M-DVD (multiple DVD's).
NOTE:
This program won't allow you to back up CSS-encrypted (commerical) DVD's, but programs like "AnyDVD" and "DVD Region-Free" will allow you to bypass the CSS-encrpytion.
OTHER NOTABLE PROGRAMS TO COPY EVERYTHING ON A DVD:
DVD2ONE**
CloneDVD**
**Won't copy CSS-encrpted DVD's, unless you use 1 of the 2 programs mentioned above.
Hope this helps -
have you used still pictures on the stuff you don't want then used deep analysis?
that should normally give acceptable (for most) quality
quality is in the eye of the beholder(and their setup)
Originally Posted by EpiMann
that will set you in the right direction -
https://www.videohelp.com/forum/viewtopic.php?t=186860
https://www.videohelp.com/forum/viewtopic.php?t=185976
there's a few methods in those threads -
Thanks guys,
Anyway, I know how to use DVDShrink (as much as there is to know) and that's not the problem. (Have used stills, deep analysis, different quality rates for different chapters (stills for end credits) etc.)
I'm only interested in knowing if there's some other software which has same options w better video encoding quality (I still think that if you go under 70% -> the quality decreases). You gave me good suggestions but there's no comments about the quality compared to DVDShrink and I don't want to test these allSpecially interested in the quality of DVD2one and CloneDVD ...
jarvis1781: what did you mean by that 'The Big 3'
And thanks again ... -
The only way to get noticeably better quality than DVD Shrink is to stop transcoding. All transcoders suffer a similar quality loss when shrinking that much.
You can re-encode, though. Check out the "big 3". Be aware, however, that in order to use the "big 3" you need Scenarist, a package which costs $25,000. Obviously some people "acquire" it in other ways.
- Gurm
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 22:30 -
What software to add menus to video
By Victor Hen in forum Newbie / General discussionsReplies: 7Last Post: 1st Jun 2010, 20:10 -
Help with what software is good for menus and chapters
By shashgo in forum Authoring (DVD)Replies: 9Last Post: 3rd Jan 2009, 17:09 -
Free Software for Motion Menus?
By thomasj in forum Newbie / General discussionsReplies: 5Last Post: 21st Nov 2008, 14:03 -
Good software for DVD menus?
By Me-Hostage in forum Authoring (DVD)Replies: 2Last Post: 4th Jul 2007, 02:39
