Hi!
I have a Pioneer DV-414 dvd player and a Plextor 708 dvd burner. When I burn a movie using DVD+rw media the dvd plays just fine in my dvd player. But when I copy it to a DVD+r using the DVD+rw as source it stops working. The dvd player says "unplayable disc" or something like that. Acourding to the DVD player compability list here on dvdrhelp my player is supposed to handle DVD+r just fine. How can this be?![]()
It might depend upon the brand of DVD +R media you use. Have you tried other brands? Also, it might depend upon how old your DV-414 is. The DVD +R spec wasn't released until mid-2002, so if your player was manufactured before then, it might not work with +R. The same model player manufactured at a later date might support +R. So you never know until you do a little more experimenting.
The brand that was used was Maxell 4x DVD+r. It was quite an early model. It might be that the player is too old
DVD works on DVD player but not recognised in laptop
By rline101 in forum DVD RippingReplies: 6Last Post: 11th Oct 2010, 16:09 -
trying to fix a scratched dvd, works on pc but not player...
By extent in forum Authoring (DVD)Replies: 3Last Post: 28th Feb 2010, 09:02 -
Sound works on Pc but not on Dvd player
By Rogert in forum AudioReplies: 4Last Post: 7th Jun 2008, 07:22 -
DVDRW works fine on PC, not on DVD Player
By Koopzer in forum Newbie / General discussionsReplies: 3Last Post: 21st Apr 2008, 02:54 -
DVD works on DVD-player but not PC
By lmcnlcy in forum Software PlayingReplies: 3Last Post: 28th May 2007, 14:47
