I have created my movie in Premiere Pro and want to burn it on a dvd (with menus i created in Ulead DVD Moviefactory) !
How do i do this without using the burn tool in Ppro.
-can i export to mpeg (tpcgenc quality) in ppro?
premiere pro features a redesigned MainConcept MPEG-1, 2 encoder that is part of the program.. It needs to be activated after several uses you need to go online and get a number to put in it to keep using the feature.
For the first 3 times you can also use AC3 encoding, but that goes away after 3 uses..
The MPEG encoder still works very well, but takes a lot longer on all my setups than the similar MAin Concept engine for MPEG in VEGAS...
The premiere pro program has all the setting you need for MPEG rendering for DVD's (MUXED or UNMUXED , etc)
It keeps chapters if you use ENCORE DVD by adobe (companion product) -
AFAIK Premiere's burning utility just puts an auto-playing video onto disc without menus. MovieFactory is your mastering app. Export the project to MPEG2 from Premiere and import into your DVD project in MF. As dcsos said the MPEG encoder is pretty good, though you may notice it to be slower than TMPGEnc. You could also save your Premiere project in DV and then encode with TMPGEnc if you'd feel you have more control over your settings that way. I used the first DVD MF a long time ago and IIRC you just import your MPEG2 stream, mix in your menus, and author the DVD. Isn't it that simple?
How do I free up my PC while Prem Pro is rendering?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 12Last Post: 30th Oct 2011, 19:54 -
Prem Pro CS 5.5 + Lagarith anyone? et. al.
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 8Last Post: 14th Oct 2011, 15:13 -
Adobe Encore CS3 - quick way to create 100 menu links?
By sdsumike619 in forum Authoring (DVD)Replies: 10Last Post: 4th Apr 2008, 23:17 -
no sound when i captured from dv in adobe prem cs. even hd didn't work
By cannibalcam in forum AudioReplies: 7Last Post: 5th Mar 2008, 08:07 -
Adobe Prem 2.0
By caeK in forum EditingReplies: 1Last Post: 1st Jul 2007, 12:21
