  1. I am looking for a good utility that will be able to give menoew files of sections of my mpeg files.
    I want to be able to cpature a complete video tape and then later trim it off, or break it into diff pieces...
    I have tried a few of them and then seem OK for cutting smallish pieces.
    It seems thoguh that once the piece I want to cut is over 2gb it does not work and either treis the create a file that is so big. or the time report for the new file is wrong.
    I even changed my disk to NTFS thinking that may be it.
    I would like something that is either free-ware or at least has a trial so I can ensure it does the job right.
    (as long as we are at it what do people recommend for basic MPEG joining too)
    Allen
    Apr 2002
    The State of Frustration
    I like Ulead Video Studio 7 (trial ware)for long captures, simple and complex editing, menus and burning.
    Hello.
  3. I want to start with an mpeg and end with an mpeg of a smaller size.
    For this toold not interesting in editing .. but cutting stripping etc.
    thanks
    Allen
    Apr 2002
    What do you mean by "cutting and stripping"?
    Hello.
