Hi freinds,
I tried to convert an *.avi file to *.mpg with VirtualDub by separating the *.wav file from the video as well as with TMPenc, but the result with the VirutalDub was: Audio didn't matched with the Video and TMPenc resulted no Audio.
Please help me with how to solve this problem, because I tried to convert this avi file to Mpg with TMPEnc but same result with no audio.
NEED URGENT HELP. Thanks
Kodomali![]()
The audio is obviously in a format TMPGEnc can't understand. First, convert it to WAV.
To do that the easy way, just load the AVI in GoldWave and save wav. If your encode suffers from desync (audio is a little too early - happens rather frequently when separating A/V and then joining them) just insert corresponding amount of silence at the beginning of wav.
/Mats
/Mats -
Thanks man,
Can you please tell me the corresponding software and steps to add silence to my wav.
How I will exactly know how much silence I have to add? Also after splitting the wav, should I use TMPEnc or Virtual Dub to add the wav with the video again?
Second thing is, if the sound is slower instead of early than video, how I will fix that problem.
Thank you anyway for your reply, please help me out if you have more time.
Kodomali -
First, after getting the WAV from Goldwave, use your AVI as video source and this wav as audio source (in TMPGEnc). Encode a short clip (a minute or so) so you can verify sync.
- If audio is too soon (ahead of picture) add silence at start of wav:
Load wav in GoldWave again, then use Insert Silence under the Edit menu. How much, you got to measure (use a stop watch) or just make an estimate from your clip.
If audio is too late (after the picture) you have to cut a piece at the start:
Measure how much, then place left marker at start of wav, and right marker at the right point in time (let's say 0.5 s), then use Cut from Edit menu.
In my experience, I've never found an AVI where the audio after separating A/V was too late, but it's not impossible.
/Mats - If audio is too soon (ahead of picture) add silence at start of wav:
Mats
You are Great....
Thanks a lot bro,
Kodomali
P.S.: Though it seemed to be very hard adding the actual amount of silence in the wave file. Couldn't find the right figure yet.
H264 conversion problem Virtualdub
By Shadowofthedarkgod in forum Video ConversionReplies: 11Last Post: 8th Nov 2015, 13:42 -
TMPEnc Authoring Works 4 Problem with input AC3 Audio (5.1 channels)!!!
By JackyWang in forum Authoring (DVD)Replies: 10Last Post: 22nd Jun 2011, 10:46 -
VirtualDub Mod Conversion from DVD, no audio in FCE
By Jralph in forum Video ConversionReplies: 2Last Post: 29th Apr 2009, 10:09 -
VirtualDub conversion
By Flying Doctor in forum Video ConversionReplies: 9Last Post: 6th Nov 2007, 04:45 -
Mpeg-1 Audio Layer 2 - Audio Tag 50 - VirtualDub, TMPEGEnc Can't Read
By Rebooter in forum AudioReplies: 2Last Post: 26th Oct 2007, 21:51
