I am considering to buy Matrox RT.X10 with Premiere Pro software bundled. For MPEG2 convertion, I plan to use TMPGEnc.
However, is it true that using Matrox RT.X100 hardware realtime MPEG2 capture/encoding much better than TMPGEnc in quality?
Any other choice to RT.X100?
Thanks.
Maybe, maybe not... depends on a few things...
Mostly just faster.. not really better.
Nice card.Want my help? Ask here! (not via PM!)
A bit of digging through through the specs of the x.100 reveals it uses the Ligos software encoder for mpeg encoding
I recall reading from a website that compared Matrox to Canopus (pro quality we talking). In conclusion it gave the edge to Matrox for better overall viewing experience of encoded material. It said among other that although detail is silighty better (under magnification) on Canopus, Matrox picture felt "right". Try to search Google it must be still there...
It seems to be one of the few cards that still works with PREMIER PRO
look here
http://www.adobeforums.com/cgi-bin/webx?128@106.xlbrboMfDI2.121725@.2ccddfc4 -
not the most stable of cards though -- http://forum.matrox.com/cgi-bin/rtx100/ultimatebb.cgi
dvstorm2 is another you may want to look at ... in the same range i believe .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
An ATI All In Wonder may do you too... it just depends on if you need all the extras of the NLE cards...
Yet another weird Premiere Pro issue (v210, extreme black)
By Asterra in forum Video ConversionReplies: 3Last Post: 2nd Jul 2011, 00:08 -
How to Import Matrox AVI Files into Vegas Pro 8
By SCDVD in forum EditingReplies: 1Last Post: 22nd Mar 2009, 20:57 -
Using Matrox .avi files in Vegas Pro 8
By SCDVD in forum EditingReplies: 1Last Post: 20th Mar 2009, 16:43 -
Import Matrox AVI files into Vegas Pro 8?
By SCDVD in forum EditingReplies: 2Last Post: 5th Mar 2009, 18:34 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 09:19
