I use MPEG2Cut to cut commercials from MPGs I download from my ReplayTV. I do this because encoded in the MPG is closed caption data, which I can extract and convert to subtitles. My problem is once I cut them, I join them with FileMerger, which then makes an MPG with incorrect timecodes. This is not loadable by any of the DVD creation programs I have. So I have to run it through TMPGEnc after which takes 2 hrs and 30 minutes, and puts over 15 minutes of the final frame on the last 15+ minutes of the new MPG. But I can't just cut out that last bit because the timecodes show something different in source range selection than is actually going to be there. So here's my question:
Is there any free or trialware tool that cuts and joins (or even just joins) MPGs together, WITHOUT a full re encode, that will correct the timecodes?
Restream is not fixing my problem. Even when I pick reset timestamps, and I zero out the first GOP timestamp, and even if I pick zero broken-link flags the stream is not loading in TMPGEnc or DVDMaestro. Is there another way to do this without re-encoding?
TMPGEnc's cut and merge removes the closed captions from the file (but it IS fast. I guess I have decided to cut and merge (without TMPGEnc), GOP fix with Restream (because that does make the length appear correct) and then reencode with TMPGEnc. What's too bad is that even doing this is not free. Is there another way to reencode an MPEG2 that IS free? I don't mean Womble MPEG VCR, I mean something I don't have to even ask for. Something that has a direct download and is free.
The old version 1.x of Mpeg2Cut has a lot of compatibility problems.
Try version 2 - Mpg2Cut2 - which resolves a number of issues from Version 1, and adds a number of new features.
Download the latest version of Mpg2Cut2 at
http://www.geocities.com/rocketjet4/
If you are having problems with Version 1,
then give Version 2 a try.
For cutting VOBs, I recommend the following::
- "menu - Output - Preamble - MAXIMUM"
- Also use "PVAStrumento" from Offerynto fix timecodes.. -
A couple of things about Mpg2cut2:
Downloading DLLs seperately is not cool (unless this is an option before download)
If the MPG is 352x480, it shows up correctly in the window, but some of the buttons are cut off on the right most side.
Otherwise, very nice work! Think about open sourcing it (if possible)?
How do I edit, cut, join DVDs, VOB, VIDEO_TS folders
By Baldrick in forum Authoring (DVD)Replies: 13Last Post: 9th Oct 2013, 06:03 -
mpeg4-ts - how to edit? Need to cut fragments and join two files
By relu84 in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2011, 07:01 -
Easiest way to cut and join video files
By zammil in forum Newbie / General discussionsReplies: 8Last Post: 15th Oct 2010, 12:04 -
Cut and Join VCD Files: tools that can Handle that
By devilcoelhodog in forum Authoring (VCD/SVCD)Replies: 5Last Post: 15th Jan 2010, 21:57 -
Good program from cut/join .mpg .wmv files.
By Beautiful Alone in forum EditingReplies: 1Last Post: 27th Jul 2009, 16:57
