I currently have an nec 1300a dvd-rw. I tried burning a backup of a dvd onto a memorex and tdk 4x dvd-r but they won't play on my ps2. Anyone know of a dvd-r or +r brand that will burn on a nec 1300a so that I can watch my dvd backups without using a modchip on my ps2? I heard that riteks are real good but I'm not sure where/which ones to buy in the u.s. Thanks in advance for any feedback.
Why dont you start by telling us your method of backing up your dvd's first. What programs were you using?
SLICK RICK
Originally Posted by lordsmurf -
I tried nero 6 and for some reason the dvd option is blanked out. I currently have my drives setup as:
primary: cdrom=master, hd=slave, secondary: cd-rw=master, dvd=rw slave. Should I have this setup differently to burn from hd to dvd=rw? Or should I try an older version of nero. I think i have 5.5.9.9 but does that support dvd burning? thanks for your help on the matter. -
Verbatim can play DVD+R movies on PS2, i have try this before but not for the games..good luck
Thanks for all the help. -
I use dvd author and my +R discs work perfect everytime. dvds range from compusa cheapos to tdk and fuji and memmorex.
haali media - use custom media type for h.264
By adom in forum Video ConversionReplies: 0Last Post: 15th Mar 2011, 06:07 -
What type of musical instrument can you play?
By johns0 in forum PollsReplies: 19Last Post: 21st Feb 2011, 23:39 -
Can the PS2 play divx avi movies?
By amjad_z4 in forum DVD & Blu-ray PlayersReplies: 30Last Post: 14th Jul 2010, 06:52 -
Media type comparison.....
By sungator in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 29th Mar 2009, 20:32 -
LCD Monitor I can play my PS2 on?
By oroboro in forum DVB / IPTVReplies: 3Last Post: 22nd Apr 2008, 09:54
