While extracting a movie with DVDShrink, is the speed of extraction standard or can it be adjust to the read speed of a particular drive? TIA
It's the decrypting and compressing that take up most of the time, not the actual ripping of the files. You can't really make that go much faster. If you have a disk that doesn't need either, it takes about 15 minutes. Otherwise, about a half hour.
ebenton, how do you know if decryption is needed. About compression, I am aware that I choose wheater I want the backup be compressed or not, but about the decryption thing, do I have any kind of control?
DVD Shrink detects if decryption is needed, and if not, won't do it.
extraction synchronized with video
By amandioc1 in forum Capturing and VCRReplies: 2Last Post: 29th May 2010, 04:38 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
MP4 Audio Extraction
By neumannu47 in forum Video ConversionReplies: 2Last Post: 28th Aug 2008, 19:17 -
How do i change the default writing speed in Nero when using DVDshrink?
By wallacem4141 in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2007, 05:15 -
video extraction
By siopawman in forum EditingReplies: 2Last Post: 9th Jun 2007, 18:42
