I was finally able to get my video encoded to SVCD. The files I muxed with ffmpeg, "testsvcd.m2v.mpg-1.mpg", has audio, and i can p[lay it in QT. I went through the procedure using MMT to make the menu and to do the build to make the .img files. However, the SVCD plays with no audio on my DVD player. Any hints as what to check for to correct?
thanks.
Results 1 to 13 of 13
what app did you burn this svcd with?
often non standard svcd burns produce symptoms like you are describing. -
thats most likely the problem
only toast 6 burns svcd correctly (i have noticed)
use Missing Media burner or Firestarter FX which you can get off versiontracker.com until you update to toast 6 -
I DL'd MMB but the readme says it wouldn't work with a Superdrive. Is this nonsense?
it doesnt work with "some" superdrives. Just open it up and give it a try. put a blank disk in and use it to get info, if you got the info and all showing up in terminal, then it will most likely work!
It sees both my superdrive and my combo drive! -
I can't think of anything more aggravating than this. I got the Toast 5.2 update, still no sound. tried MMB, and got this:
IODVDServices: PIONEER DVD-RW DVR-104 Rev: A227
Using driver: Generic SCSI-3/MMC (raw writing) - Version 2.0 (options 0x0000)
Starting write resid: 68
at speed 8...
Pausing 10 seconds - hit CTRL-C to abort.
Process can be aborted with QUIT signal (usually CTRL-\).
resid: 104
Turning BURN-Proof on
resid: 104
resid: 104
ERROR: Cannot setup disk-at-once writing for this drive.
ERROR: Writing failed.
So much for macs being easier to work with -
well right now it seems the only option is to get toast 6.
Toast 5's ability to burn svcd's is nill. Toast 6 is great, but it means upgrading which means $$ unfortunately
since you have a superdrive, have you considered just turning them to dvd? -
To come up with a better solution, I would like to know your exact settings in ffmpegX and your terminal ouput. I don't think that this should be something we blame toast for yet.
Let me know your exact settings and I'll do what I can to get you up and running. -
I have always used Toast 5.2 to burn my (XS)VCDs and it has been OK.
Have you tried to author the SVCD with VCD Builder?
http://homepage.mac.com/johan/
Have you inspected the file with tools like mpxtx.
http://www.biermann.org/philipp/mpegcut/ -
I can't use mpgtx, it doesn't work for me. The progress bar jsut spins and spins.
I didn't think vcd builder worked for svcd's. Should i try that?
When encoding using ffmpeg, I get
Encoding started on Tue Nov 11 19:28:48 EST 2003
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
Input #0, avi, from '/Documents/Newstuff/Rugbydata/Forimporting/testsvcd.avi':
Stream #0.0: Video: msmpeg4, 640x352, 25.00 fps, 800 kb/s
Stream #0.1: Audio: mp3, 48000 Hz, stereo, 128 kb/s
Output #0, yuv4mpegpipe, to 'pipe:':
Stream #0.0: Video: rawvideo, yuv420p, 480x480, 23.98 fps, q=2-31, 200 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
++ WARN: [mpeg2enc] 3:2 movie pulldown with frame rate set to decode rate not display rate
++ WARN: [mpeg2enc] 3:2 Setting frame rate code to display rate = 4 (29.970 fps)
++ WARN: [mpeg2enc] Generating dummy SVCD scan-data offsets to be filled in by "vcdimager"
++ WARN: [mpeg2enc] If you're not using vcdimager you may wish to turn this off using -d
Then I was able to mux it OK -
foa, it looks like a PAL source being encoded into NTSC... Secondly, the audio is NOT being encoded.
How are you muxing this? and with what files? -
I'm not sure what format the original AVI was, anyways, wouldn't processing it reformat it to be svcd compatible?
For some reason ffmpeg never processes my audio simultaneouly, I have to do a separate encode.
I also converted this file with the QT mpeg2 encoder, but to do it first, I have to delete the sound track.
With ffmpeg, I coverted the audio to mp3 then to mp2 to mux using ffmpeg or MMT, I can't remember which.
But I was finally able to get a muxed .mpg in mp2 format where the sound played OK. However, I tried VCD builder, but it said that the format was incompatible.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
editer shows 'no sound', mpg plays with sound
By oldvideote in forum EditingReplies: 3Last Post: 7th Jul 2007, 09:01 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
