Good Afternoon All
This is my first post here so I hope I am in the right forum. I am using DVD MovieFactory 2 SE that I got with my DVD-R burner. I am currently trying to drag and drop MPEG, AVI, ASF files and so on to make them into a DVD and for the most part I can get them to work fine but on a good portion of the clips that I have when I try to import them I come up with a "file format mismatch" error. Is this as simple as a bad file name or is it someting more complex and will I be able to have these files converted into DVD's
Thanks for the help
Redeemer462
Results 1 to 1 of 1
Error: The source image format is not acceptable (error code -2)
By Russo in forum DVD RippingReplies: 3Last Post: 5th Jul 2011, 11:50 -
Ulead DVD Factory 6 File Format Mismatch
By nala310 in forum Authoring (DVD)Replies: 1Last Post: 17th Jan 2010, 04:20 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 09:59 -
DVD Audio format mismatch?
By Scally in forum Authoring (DVD)Replies: 4Last Post: 17th Jan 2008, 09:07 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
