I got hold of a movie in pal ogm format. Since then I have spent several frustrated hours trying to convert it to ntsc svcd![]()
First I found out that ogm files are made up of mpeg2 video and ogg vorbis audio (please correct me if I'm wrong). I found a program that comes with AVI2VCD called decompress that extracts the ogg audio to pcm and muxes it with the mpeg2 video to create an avi. A pal avi.
I next loaded this avi into tmpgenc, with pal svcd template, and created a pal svcd version of the movie.
This is where I'm stuck. I was hoping to load the pal svcd into tmpgenc and convert to ntsc svcd, but tmpgenc won't load the very pal svcd it just created! Trying to open the mpg causes the program to crash. Trying to open the m2v (tmpgenc demuxed the mpeg2 without problem) causes the error "can not open, or unsupported."
What could cause such strange behavior in tmpgenc (not that this is the first time I've had problems with the prog)? How can I work around this?
Results 1 to 1 of 1
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 10:55 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 16:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
PAL to NTSC Conversion with DD
By cottage in forum Video ConversionReplies: 5Last Post: 16th Feb 2009, 17:10 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
