hello!
I got a couple of mpg streams which Nero won't recognize as it is a Videocd compatible mpeg stream. Nero ask me to turn off v2.0 compatibility (and making the stream some 7 (!!!) minutes longer) or to re-encode the file to Videocd format BUT when I select this option Nero hangs up.
Someone please know of a stand-alone program who can re-encode non-Videocd format mpeg files to Videocd mpeg files??
thanx in advance!
Davy
yes, TMPGenc can make a VCD compatible mpeg file but I found this out AFTER I encoded some 6 movies to .mpg, and to encode them again (mpg to mpg) creates a bit loss of quality I guess
No, I'm searching for a look-a-like encoder which Nero uses to reencode the stream so that it meets VCD standards... this process only takes some 2 minutes to complete.
Was your VCD original compliant with VCD Standards? Or is just some random MPEG-1 file you have? If it really was VCD Compliant, try running one of thos MPEG-fix programs. Forgot what they were called... =|
or VCDGear might too...
Standard quality/size for MPEG (*.mpg) videos?
By Ashman01 in forum Video ConversionReplies: 3Last Post: 22nd Feb 2009, 19:55 -
Card with mpeg-2 hardware capturing for standard definition?
By Giantsloth in forum Capturing and VCRReplies: 3Last Post: 27th Oct 2008, 19:26 -
videoCD to dvd
By rubberman in forum Video ConversionReplies: 9Last Post: 31st Jul 2008, 14:59 -
Pioneer DV-400V Any way to play standard MPG/MPEG-2 files from USB or disc?
By flobie11 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 2nd Feb 2008, 07:09 -
Making all videos standard resolution?
By Conformist in forum Video ConversionReplies: 7Last Post: 7th Jul 2007, 03:11
