i treid just opening the movie in virtuadub without changing any settings and the wav came out all jirky.
so i tired the tutorials on here that say change a few settings, how these happen
here is the file info
Results 1 to 9 of 9
-RoMeRz: Don't stay still while walking...
looks like you are missing a codec (maybe an ac3 codec?)
try to install GordianKnot codec pack, it might work.
get it here - http://keihanna.dl.sourceforge.net/sourceforge/gordianknot/GordianKnot.CodecPack.1.3.exeHELL AINT A BAD PLACE TO BE -
cheers m8, ill install that now and post how i got on
-RoMeRz: Don't stay still while walking... -
right here is what comes up
i clicked the web button beside the audio bit and downloaded what it said, but i still get exact same as the error above
btw cheers for all the helps lads.-RoMeRz: Don't stay still while walking... -
In the tools section under "virtual dub tools" download the ac3 ACM decompressor. Install it and then load your film in v-dub. Choose audio>full processing mode. Then choose audio>compression>ac3 ACM decompressor. Then file>save as wav. This should solve your problem. If not, use goldwave as Baldrick suggested.
HURRAH ITS GOING
cheers all
adding subtitles isn't working anymore
By kategabrielle in forum ffmpegX general discussionReplies: 3Last Post: 26th Jun 2010, 05:36 -
Taking Audio from movie file, then burning audio to cd-r
By Justnmnmn in forum AudioReplies: 5Last Post: 22nd May 2009, 18:44 -
I use TMpgEnc to convert MOV to DIVX. But the quality of AVI isn't good
By natong in forum Video ConversionReplies: 0Last Post: 11th Apr 2009, 01:21 -
Premiere is taking >7hours vs. TMPGEnc only 20min???
By alegator in forum EditingReplies: 6Last Post: 11th Oct 2007, 11:38 -
Vista DVD Maker (isn't working)
By naomi c in forum Newbie / General discussionsReplies: 3Last Post: 3rd Aug 2007, 05:30
