hey im kinda of a newbie at this so dont grill me for saying something that i shouldnt...but i just recieved an mpeg video which is 3 cds long and was wondering if i can convert it somehow so that i would be able to play it on my playstation 2 which can play dvd-r's...if anyone has any info on this can u please contact me at kngcbra33@aol.com...thanks in advance for your help...rick
Well if you have the Pioneer DVD burner, you should be able to do it.
You have to re-encode the mpeg to be DVD compliant, Ulead MediaStudio Pro 6.5 has an option for converting and it does it well. Considering it is a really new ad expensive software I will take for granted you don't have it. Then what you need to do is convert thhose mpeg files to AVI and then re-encode to mpeg DVD compliant files.
I also think TMPGenc can help you with this, but I'm not familiar with TMPGenc, may be someone else can take it from here.
Alfonso -
TMPGenc, CCE, Ulead, etc. can make DVD MPEG2 files. The real question is do you have a DVD burner? If so you'll need to get the MPEGs from the x(S)VCD on your HD (for VCD use VCDGear or SVCD just copy MPEGS).
Now you have two choices, either burn them on a DVDR disc, or re-encode to DVD MPEG2 and burn them. If you want them to work on your PSX2, you'll have to re-encode.
TMPGenc, CCE, Ulead, etc can do this. TMPGenc is 100% free but kind of slow. Look at the link to the left under "Author" for more info. -
im sorry i dont have a dvd-burner just a cd-r one..so im guessing i wont be able to do this..please help me out if u can
Nope bartender you are SOL, CD-R burners can not burn DVD-Rs just like CD-roms cant read DVDs.
Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
By jglass in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2008, 21:51 -
Converting .mpeg files to watch on DVD?
By prankstare in forum Video ConversionReplies: 7Last Post: 8th Jun 2008, 21:41 -
Converting IPOD videos to a MPEG for a DVD
By bmedlen1 in forum DVD RippingReplies: 2Last Post: 8th Feb 2008, 08:25 -
This is a minefield! (converting mpeg to mpeg for DVD)
By uth in forum LinuxReplies: 29Last Post: 18th Nov 2007, 16:04 -
Converting mpeg to use in dvd
By demonwarrior in forum Newbie / General discussionsReplies: 6Last Post: 17th Aug 2007, 05:33
