I have this particular mpeg2 video.
After opening it with WMP, WMP tried to download a codec but failed.
In the end, I can watch the video but there's no audio.
Looking at the files properties, the audio codec is UNKNOWN and the video codec is CyberLink Video/SP decoder.
NOTE: This problem is funny cause few days ago WMP was able to download the audio codec. But now it cant.
Did you try loading your video file into gSpot (it's really desgined for avi's, but it can sometimes tell you something useful about MPEGs too).
It sounds like your file may have ac3 audio (I can't remember, but think it's possible to have an MPEG-2 file muxed with ac3 audio - that's what most DVDs are after all).
If so, try downloading ac3Filter or something similar.
Do you have WinDVD or PowerDVD? - they should be able to play ac3 audio that WMP can't.
cheers,
mcdruid. -
Hello,Originally Posted by theDruid
Thanks for the reply. I dont have those players because they are not freewares you see. GSpot didnt provided a great help on this file because it is in MPEG format I guess. I installed AC3 but it didnt work. Sigh this is so frustrating, few days ago the file still works fine.
More audio sync problems (MPEG2)
By mahonni in forum AudioReplies: 41Last Post: 15th Jan 2012, 15:08 -
Remove audio from MPEG2
By paulocon in forum AudioReplies: 5Last Post: 23rd Nov 2010, 07:07 -
no audio in mpeg2 recorded file
By harmeetmatta in forum AudioReplies: 3Last Post: 4th Jun 2010, 11:06 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
MPEG2 Video with AC3 audio cannot convert to MP3 audio
By wenglock in forum ffmpegX general discussionReplies: 0Last Post: 7th Sep 2009, 21:52
