I want to add extra lines of code but don't know what to use and how to save it. Anyone know how?
You can usually open .inf files in notepad (or an editor designed for coding like CrimsonEdit).
Don't just double-click on the file - either open your editor, and open the file from there, or right-click on the file, and choose Open file with... Make sure you don't have Always open this type of file with.. checked, unless you want to mess up your file associations though.
I hope you know what you're doing once you get inside it!
cheers,
mcdruid. -
Thanks I was able to figure it out. However, notepad would not save inf files. I had to save it as txt file, then rename the extension back to inf.
Autorun.inf virus in flash drive
By shans in forum ComputerReplies: 7Last Post: 22nd Aug 2011, 19:29 -
Trying to modify Blurry MPEG files
By homantam in forum Newbie / General discussionsReplies: 5Last Post: 24th Feb 2010, 23:47 -
Questions about sysoc.inf and msconfig in Vista
By Xylob the Destroyer in forum ComputerReplies: 2Last Post: 10th Dec 2008, 14:08 -
Possible to Modify MKV?
By BlaenkDenum in forum Video ConversionReplies: 3Last Post: 3rd Apr 2008, 02:43 -
line 2207 of the inf file \dell\txtsetup.sif is invalid
By SIRCOOKS in forum ComputerReplies: 2Last Post: 17th Mar 2008, 12:26
