  1. I have an mpeg movie (which plays fine on the pc and also as a vcd). I copied the mpeg off the vcd so I could try and make another vcd out of it with menu's. I am using tscv .74 and also tried .73.
    Here is the output I get when I try to create me bin/cue. It seems to get through the menu's, but screws up on the mpeg movie file.
    "mpeg scan: pack header code (0x000001ba) expected, but 0x52494646 found (buflen = 2324)
    ...this looks like a RIFF header but a plain multiplexed program stream was required.
    input mpeg stream has been deemed invalid -- aborting "
    PLEASE HELP!!!! Or is there a better way to make menu's with vcd's that with tscv?
  2. I don't think this is a TSCV problem.
    Try downloading VCDGear out of the Tools section (http://www.vcdhelp.com/vcdtools.htm). Use this program to convert the DAT file to an MPEG file. This will probably take care of your problems.
    Good luck!
    - bewley
  3. Thanks! I will give that a try.
