  1. Anonymous
    Guest
    Trying to encode a Vob to mpeg 2-DVD I got following errror message
    Encoding started on Sun Nov 9 15:14:16 CET 2003
    INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
    INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
    INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
    ## Component Manager: attempting to find symbols in a component alias of type (regR/carP/x!bt)
    usage: movtoy4m -w width -h height -F a:b -a a:b [-s] [-f] [-o ppm/y4m] movie.mov
    example: movtoy4m -w 352 -h 288 -F 25:1 -a 4:3 pal_normal.mov
    example: movtoy4m -w 352 -h 240 -F 30000:1001 -a 16:9 ntsc_wide.mov
    **ERROR: [yuvscaler] Could'nt read YUV4MPEG header!
    **ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
    What´s the problem? What could I do?
  2. Open your VOB in Quicktime. Does it work? If not, you need the mpeg-2 QT player component.
    Alternatively, enable the "Decode with mplayer" option to switch off Quicktime.
  3. Anonymous
    Guest
    Thanxx alot for this help ,ujust save me from getting mad#!**
