I have a problem.
My new DVD-player doesnt accept SVCDthat I made with VCD Builder from MPG-files. It only accepts SVCD
that are made from BIN/CUE-files. So I have a bunch of movies I cant watch. Fine, I thought. I'll just take the MPG-file of the CD and make it a BIN/CUE-file (dont know how to do that either). But when I try to copy the MPG file from the SVCD I cant. I get an error. I've tried on different computers (Mac) on the buildt in CD and an external USB CD.
Does anyone know how to do this?
Please help me!!
you cant just copy the .mpeg over to your desktop. you have to image the entire cd using toast 1st. save to your hd by going to file , save as disk image. Onceyou have that, just rename it to .bin.
open VCDTOOLSX and use the extract .mpeg function to pull the mpeg out of that particular .bin file.
then, use the VCDTOOLSX image maker to take the .mpeg you just extracted and create a new .bin/.cue set.
you can then burn that one with toast 6, MMB or firestarter fx
repeat as needed for each disk.
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
svcd on windows 7 : Vob Size problem?
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 24th Jan 2010, 13:58 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
svcd problem crashing with SP3
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th May 2008, 16:38 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
