    Nov 2003
    I've used DVD Shrink for a while to back up my dvd's but it doesn't allow me to copy both the menu and the movie without the extras so I tried the Guide how to do that with AnyDVD and CloneDVD. It worked like a charm but then I got one problem.
    Since I'm the only one to use the film I don't have any need for all the sound options (dd & dts & 2.0) so I strip them away just keeping the best audio and swedish or english subtitle.
    Here's the problem, not a big one but anoying. When I start the movie it still thinks that all the sounds are on the dvd so the movie can start on different audio settings which means no audio. I want to get rid of the choices so I just got the DTS option and swedish subtitles (not 17 more I need to scroll through).
    Any Idea how I can make this or atleast set the audio that still is on the dvd to standrard.
  2. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    you can get rid of the audio/sub references by using Ifoedit
    it may be a little complicated if you are not used to using Ifoedit but basically all you would do is remove the info regarding the streams you don't want
    there may be a guide somewhere on how to do this as I've seen a few floating around
    try 2COOL's guides, I'm sure he will have something similar
