    Dec 2002
    I am trying to find the main menu using DVD SHRINK nut i cannot find it!! i am using the reauthor button and have examined all the files but cannot find it, will it be hidden?? any ideas????
    Oct 2003
    Grovetown, GA
    Greetings,
    You lose the menu with re-author. It is a functionality that has been asked by the users to the programmer writing this wonderful FREE software. It may takes a little while before the programmer implement it. Or perhaps he won't never implement it. Who knows.
    There are a lot of guides explaining how to use tools like IFOedit if you want to re-author. But it is not as easy as a drag&drop solution.
    Thank you
  3. Most of the time the menu, if it is animated, will show up in the menu section when doing reauthor (like 3beta5). In the past menus that are text, don't seem to show up in reauthor mode.
    Anyway I have recently found that the menu can be dragged into the title or workspace(cant recall what its called) area where you drag the movie itself.
    The menu will not be useable but will show as a short movie, then the regular movie will show.
    I've been doing this trick on cool menus lately.
