How do I find out what a particular AVI file's data or bitrate is? My UleadVideo studio usually shows something like 131.64 Kbps, for all of my downloaded DivX movies, which doesn't seem right. It's never below 120.00 or above 140.00. And that's the DATArate, or at least that's what it says next to it, as opposed to BITrate which is what it says for mpegs, which are usually 1150 kbps (what's the difference between data and bit rates anyway?) I want to know this because I want to reencode the DivX files to MPEG2 with the same bitrate. I don't want to lose quality by making it lower or unnecessarily lose space by making it higher. Please help
.......I want to reencode the DivX files to MPEG2 with the same bitrate. I don't want to lose quality.......
Divx is crap. Want quality - Buy the DVD.
Under Type select DivX - Enter run time of movie - TADA - bitrate.
How can I change the color depth of an AVI file? 32-bit to 24-bit
By evansste in forum Newbie / General discussionsReplies: 0Last Post: 10th Jun 2011, 01:17 -
avi data rate too high?
By hello2000 in forum Video ConversionReplies: 5Last Post: 3rd Aug 2010, 10:43 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 12:53 -
Reducing bit rate of AC3 file of DVDs
By rock_king_my in forum AudioReplies: 9Last Post: 7th Dec 2007, 05:33 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 05:48
