I've given up trying to make a decent VCD using my ATI AIW card's capture program. It captures just fine but the resulting file is impossible to edit. Many programs won't even open it and the ones that do give bad audio sync problems after any kind of editing.
So, I'm going to try the VirtualDUB method instead. Using the Huffyuv codec about how much hard drive space is needed for an hour of video?
Obviously depends on frame size, frame rate, colour format, and audio format/compression.
As an example, from which you can extrapolate,
384x288, 25fps, YUY2, PCM Stereo 44kHz - 9800 MBytes
384x288, 25fps, YUY2, MP3 128KB/s - 9500 MBytes
Capturing in RGB24 adds about 50%
HuffyUV Vid Has Crazy Colours in VirtualDub and Vegas But Plays OK in MPC ?
By blewyn in forum Video ConversionReplies: 1Last Post: 5th Apr 2012, 10:31 -
No Huffyuv Codec under VirtualDub Compression
By Ryutso in forum Capturing and VCRReplies: 7Last Post: 28th Jan 2011, 02:31 -
Image sequence - VirtualDUB - HuffYUV - washed colors
By Bucic in forum EditingReplies: 35Last Post: 8th Oct 2010, 14:42 -
HuffYUV Question.....
By vipin in forum Video ConversionReplies: 7Last Post: 7th May 2010, 12:36 -
VirtualDub crash involving Huffyuv
By Xoanon in forum EditingReplies: 4Last Post: 15th Jun 2007, 17:33
