The help and the user guides aren't helping much, but I'd like to know what the "Enable VCD Menu" option does when you choose to burn a movie. You see it in the window where you add the file to be encoded/burned. When it's enabled and I click to the next screen, I see this black window with squares on it and "Created with Nero" at the bottom. Is it for creating a table of content (ie. chapters)? All I want is just the movie, so it should be unchecked? Thanks.
Hi there!
'Enable VCD menu' does exactly what it says in Nero!
It gives you the option to create a menu for your VCD which will enable you to choose using the number keys on your remote which movie portion on your VCD will be played on your DVD/VCD player.
If you only have one movie, and you dont need the menu, just leave this option unchecked.
LeoNapierThe Truth Is Out There - X Files
Render Settings Nero 11
By Firelance in forum Newbie / General discussionsReplies: 1Last Post: 18th Feb 2012, 04:01 -
Question about x264's Tuning settings
By CubDukat in forum Video ConversionReplies: 0Last Post: 4th Dec 2011, 23:17 -
WMP settings question
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 8th Jan 2011, 15:08 -
XVid codec settings question?
By 3thman in forum Video ConversionReplies: 5Last Post: 10th Oct 2009, 16:36 -
Nero Vision 3 format Settings?
By LiBiDoXP in forum Newbie / General discussionsReplies: 1Last Post: 1st Jul 2007, 17:53
