If a DVD won't fit on a standard DVD-R, is it possible to make a working copy of it without the menus or extras, not by ripping and doing work on the video itself, but simply by exluding certain files?
With DVD-SHRINK you can do that exactly as you want. I have a lot of DVDs with only the movie. This way you almost retain the quality, or in a lot of cases, there's no need to re-compress, so the video is exactly as the original.
With the option RE-AUTHOR on DVD-SHRINK, you can put or exclude what you want on the dvd. You can put, foe example, the initial studio animation, a trailer of the movie and the movie. You can level the quality of each segment and also keep or eliminate subtitles/foreign audios. DVD-SHRINK compress & create the correct files to make your disc works perfectly. In this case, when you put the finalized DVD on your player, all files are played in the order you specified on the program. You have access to the audios /Subtitles through your remote control.
Give it a try. This program is a marvel and is free.
You can burn the resultant files with nero, or, i recommend Record Now Max...100% compatible DVDs.
Big Saludos from Guadalajara, Mexico
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 14th Mar 2008, 00:19 -
Remove extras and keep the original menus
By jujuandhuhu in forum DVD RippingReplies: 4Last Post: 7th Mar 2008, 09:55 -
need info on creating new menus on dvds
By TazDevil in forum Newbie / General discussionsReplies: 2Last Post: 13th Jan 2008, 16:55 -
How do you make menus for dvds....
By mmmipa in forum Newbie / General discussionsReplies: 1Last Post: 2nd Nov 2007, 13:33 -
keeping the menus, removing the extras
By Belfour in forum Authoring (DVD)Replies: 5Last Post: 23rd Jul 2007, 10:27
