Anyone have a VHS capturing method that works using the Matrox Extreme? The manual that comes with the system uses Adobe Pro and I can't get it to work. Thanks
what do you mean it doesnt work ? what does it do ?
did you ask matrox customer support ?
did you check the matrox forum for this product"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Airport extreme router
By Marccc in forum MacReplies: 5Last Post: 19th Nov 2010, 13:01 -
Airport extreme
By Marccc in forum MacReplies: 3Last Post: 26th Oct 2010, 13:30 -
Problems with Decklink HD Extreme
By stunner21 in forum EditingReplies: 1Last Post: 27th Oct 2009, 12:31 -
Matrox MX02 Mini or Matrox MX02 Mini Max
By Cingular in forum Capturing and VCRReplies: 0Last Post: 14th Oct 2009, 20:27 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 08:19
