I have a problem that has been driving me nuts!! With DVD2SVCD -- 55% thru muxing my MPG file, bbmpeg just stops dead in it's tracks. Still shows as running in APPLICATIONS and the PROCESS is at 99% CPU utilization. It just never finishes and I have no alternative but to kill the program. I am running WinXP and this happens on 2 different systems when converting to MPEG-2.
I have tried installing the bbmpeg XP patch -- but DVD2SVCD reports an error stating the the bbmpeg.dll is incorrect. It seems the bbmpeg.dll used by DVD2SVCD is a modified version.
There is a twist However -- if I use the older DVD2SVCD 1.1.2b1 -- it works fine on both systems. Anything newer and no go! I like the newer versions of DVD2SVCD as it works better with AVI's using various encoders (i.e. HuffyUV, MJPEG, etc.). as 1.1.2b1 says it could not find the codecs (lthough they are installed and they do work with newer DVD2SVCD versions).
I even copied the 1.1.2b1 bbmpeg.dll and dropped t into the newer DVD2SVCD BBMPEG folder. No difference. Still stops while mux'ing at 55%.
This is not isolated to one AVI file, but any AVI file -- even while processing DVD rips. Nothing in the log files to indicate a probelm -- it just stops mux'ing w/o errors.
Any ideas -- please !!!!!!
Thanks !!
Results 1 to 1 of 1
Anybody here ever do DJ'ing? Looking for advice...
By jbd5010 in forum Off topicReplies: 0Last Post: 12th Jan 2012, 18:28 -
AVI-MUX: How do I mux avi file with a setting of "preload=512?"
By Stealth3si in forum EditingReplies: 3Last Post: 1st Feb 2010, 10:10 -
help with re-sync'ing Audio please
By snadge in forum EditingReplies: 14Last Post: 25th Jan 2010, 16:34 -
Dj-ing help. How to do it?
By foton in forum Newbie / General discussionsReplies: 6Last Post: 11th Sep 2009, 17:10 -
h264 + ac3... .mkv mux in synch, .avi mux out of synch...
By homerpez in forum Video ConversionReplies: 0Last Post: 5th May 2007, 05:42
