Hi. Just want to find out if my Pioneer DVDR 106D (1.07) supports the DVD+RW Real Time Video (+VR) Format or not ?
Using Nero Vision Express 2 I cannot find +VR option for making DVD Video.
JanneK999
I could be wrong, but my understanding is that only the standalone DVD+RW Recorders record in DVD+VR mode. You could then take the DVD+R/RW disc recorded on the standalone and edit it on your PC using any of the DVD+VR capable softwares.
Moments later...
After reading the product brochure, here's what I found:
DVD-Video (VR) For DVD+R/+RW
* Create new DVD+VR
* Import DVD+VR, edit titles and menus
* Change menu and add more titles after recording on DVD+R/+RW
* Delete, trim, split, change chapters on DVD+RW
* Disc recording with realtime MPEG-2 encoder
So it looks like you need a realtime MPEG2 encoder in order to record in DVD+VR mode or you must have a DVD+R/RW disc that is recorded in the DVD+VR mode for you to edit. And it's not whether your burner supports DVD+VR (data is data no matter which recording mode you choose), it's whether your software/hardware supports it. -
Thanks for your answer Gil, so far I've not seen any info about 106D and DVD+VR, on the other hand the new Plextor x8 multi DVD writer it says that it handles DVD+VR (both write and read) and even DVD-VR (only read !!!). This makes me confused and I'm not 100% sure if the DVD+VR issue is only dependent on compliant software and a DVD+WR or compliant software and a DVD+WR with +VR capability.
I cannot test your idea about real time MPEG encoder because I do not have one at the moment, but I think my computer is fast enough to encode MPEG2 in real time with soft encoder. When I capture via RGB in on my Gainward graphics card with VI-VO functionality it seems that the MPEG2 file created on HD is complete the moment I finish recording. I use PAL, 576x720 25f/s, VBS 7000, MPEG2 Stereo Audio, I use either Ulead DVD Workshop or PowerVCR II, v3.0. In the future I'll invest in a stand alone DVD recorder and therefor I'd like to use the DVD+VR format from now on.
jannek999
Blu-ray ripping to compatable format to support Samsung 40C8000 TV
By Mad Professor in forum Blu-ray RippingReplies: 1Last Post: 16th Jul 2010, 15:21 -
How to watch a .avi file in a dvd player that support divx format?
By albi123 in forum MacReplies: 5Last Post: 18th Feb 2010, 09:53 -
Machete 3.3 released - now with FLV format support
By MacheteSoft in forum Latest Video NewsReplies: 1Last Post: 7th Jul 2009, 13:12 -
Does DVDFAB support to convert blue ray dvd to ipod format?
By linda.0p in forum Blu-ray RippingReplies: 1Last Post: 3rd Nov 2008, 03:56 -
Looking for DVD player replacement - Good DVDR media support? (~£50)
By John_Jordan in forum DVD & Blu-ray PlayersReplies: 1Last Post: 18th Mar 2008, 15:12
