I was using sonic mydvd with fair results to author DVD's. If I fed it DVD compliant captures it seem to only transcode the audio which didn't add but a few minutes or so to the burn. With my new DVD burner I am using ArcSoft. It seems to want to transcode anything I give it. I have also tried Nero Vision Express with the same results.
So I would like any recommendations as to a decent authoring tool that I can simply drop DVD compliant captures to with little or no re-encoding.
I use an ASUS A7N8X with an AMD 2400 and a AIT AIW Radeon 7500 and MMC 7.7.0
Originally Posted by skunk
You can also try DVD-Lab which will also not re-encode but I think that the program is a bit buggy as I had some problems with it. The only real benefit to using DVD-Lab over TMPGEnc DVD Author is that DVD-Lab allows for greater control over the MENU design so you can get really fancy if you like.
Both have free fully featured 30 day trail periods before the LOCK UP on you and need to be registered (aka purchsed).
Thanks, tried the demo and it worked great. No Audio or Video Trancoding. Built my DVD in less then 10 minutes. I also like the fact that it puts it out to a VIDEO_TS folder so I can preview my results before writing.
Will get my money back from the other guys and buy this product. -
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
Best Authoring Tool for BD
By michcio in forum Authoring (Blu-ray)Replies: 2Last Post: 24th Jan 2012, 03:40 -
authoring tool for HD video -> DVD
By feh in forum Authoring (DVD)Replies: 2Last Post: 13th Jan 2009, 14:03 -
Which DVD Authoring Tool ?
By Leo48 in forum Authoring (DVD)Replies: 5Last Post: 1st May 2008, 15:37 -
What is a good authoring tool?
By breeze9 in forum Authoring (DVD)Replies: 1Last Post: 26th Jan 2008, 00:17 -
Which DVD Authoring tool to use?
By jodajen2 in forum Authoring (DVD)Replies: 6Last Post: 14th Nov 2007, 09:21
