hi all
just bought a btc dual writer and some mirror platinum dvd-r 4x discs
first time ive used a dvd writer so please bear with me!
converted an xvid avi to mpeg2 using mainconcept
then converted this to vobs using tmpg dvd author
this gave me audio ts and video ts folders
in the video ts folder this is what is in
video ts
video ts bup
video ts ifo
vts 01 0
vts 01 0 bup
vts 01 0 ifo
vts 01 01 - 1.4gb
vts 01 02 - 1.4gb
vts 01 03 - 1.4gb
vts 01 04 - 51mb
i then burned this to dvd using nero 5 at 2x (iso/udf using nero wizard)
now the problem
******* disc isnt recognised by anything i put in even the computer
just says no disc
unfortunately i havent got any other dvd media as yet but have burned a cdr with no probs
is it the media or something else
any help appreciated cause im stuck at the mo
cheers
themoose
Sounds to me that you are on the right track with the converting and authoring, so you may be right in your assumption that the problem might be the media. But I would suggest trying to play it on a few other dvd players if possible, just to see if it would play at all.
SLICK RICK
DVD Writer problem
By tapal in forum ComputerReplies: 3Last Post: 23rd May 2008, 05:36 -
DVD writer problem???
By championjosh in forum DVD & Blu-ray WritersReplies: 6Last Post: 26th Feb 2008, 15:04 -
Problem, with my PIONEER 111d writer
By Gewin in forum DVD & Blu-ray WritersReplies: 7Last Post: 24th Dec 2007, 07:51 -
problem with dvd writer
By daniel1800 in forum DVD & Blu-ray WritersReplies: 9Last Post: 7th Jul 2007, 18:47 -
dvd writer problem
By ellabbs in forum Authoring (DVD)Replies: 1Last Post: 6th May 2007, 04:47
