I have been trying to compress a mpg file (made from a dvd) to divx to play on my gp32 and I can't get my movie to compress at all, I always get errors such as
An out-of-bounds memory access (access violation) occurred in module 'L3CODECP'...
...while compressing audio using "Fraunhofer IIS MPEG Layer-3 Codec (professional)" (Audio.cpp:1713)...
...while running thread "Dub-I/O" (thread.cpp:120).
I've tried using xvid, divx, with and without audio, and it always crashes.
Please someone help.
Has no one else ever had this problem?
I have no idea why it keeps doing this
You don't say what software you're using - VirtualDub, I presume?
If the problem is encountered in the audio stream (which is what it looks like), you should try to split the audio and encode it separately.
The simplest way to do this is to load your mpg into GoldWave, then Save as.. a wav. Then use this wav as the audio source in VirtualDub (Audio->WAV audio...).
Alternatively, you could compress and save the audio before saving it out of GoldWave. The LAME mp3 codec can be plugged into GoldWave to allow it to save as mp3 (if that's the format you want to use).
cheers,
mcdruid. -
Yea I'm using VirtualDub (The subject name gives it awayYou don't say what software you're using - VirtualDub, I presume?
Thanks for your reply, I'll try it out.
Divx/Xvid problem in Virtualdub (not mod)
By leeqk in forum Newbie / General discussionsReplies: 14Last Post: 11th Apr 2010, 02:18 -
problem with Dr Divx & VirtualDub Mod
By pcb in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2008, 14:59 -
What exactly is the problem Virtualdub has with Divx multipass?
By Onceler2 in forum Video ConversionReplies: 14Last Post: 20th Aug 2008, 19:00 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08 -
Problem with Divx/Xvid with Winamp and Virtualdub
By mekuka_pinasem in forum Software PlayingReplies: 5Last Post: 1st Aug 2007, 12:41
missed that!
