What is the best method to convert a raw AVI (I have a Pinnacle Studio Analogue to Digital capture kit rigged up to my PC and VCR) to DivX?
I have used Stoik Video Convertor but the DivX avi that it outputs is very jumpy. And when I try to use VirtualDub, it estimates the file saize at about 1.6 Gigabytes. When it really should be at about 600-700 Megabytes.
So what is the best method to convert a raw avi to a DivX avi? At the moment I have just captured a movie from VHS to a raw avi (which is actually a best quality MJPEG).
Thanks in advance.
Yours,
Beev -
Did you check the bitrate? If it's set too high, the file will be huge. I prefer 1000-1500.
Dont know how to. Do you mean the bitrate of the DivX to be output?
How do I do it in VirtualDub?
Thanks in advance.Yours,
Beev -
yes, the DivX file to be output.
In VirtualDub, select:
Video>Compression>DivX Codec>Configure>Bitrate Control>Encoding bitrate
The default bitrate is set at 780. Maximum is 4000. But I prefer 1000-1500.
Don't forget to compress the audio as well if the original file is PCM.
converting raw teltext data into other subtitle formats
By zorr00000 in forum SubtitleReplies: 8Last Post: 18th Jan 2012, 05:12 -
muxing raw h264 with raw g711 to mp4 continer
By niror in forum Newbie / General discussionsReplies: 5Last Post: 23rd Aug 2011, 11:25 -
HD Camcoder RAW file editing and converting.
By Bonie81 in forum Newbie / General discussionsReplies: 0Last Post: 1st Jul 2011, 12:30 -
Getting Avisynth to import raw avi without converting to RGB
By Asterra in forum Video ConversionReplies: 18Last Post: 22nd May 2011, 20:08 -
Converting a 60fps .MTS video to a 30fps raw .AVI?
By Anon1 in forum Newbie / General discussionsReplies: 1Last Post: 20th Jun 2010, 15:57
