  1. am trying to burn a vcd with nero but when i try to play it, it wont run at all? nver had any problems b4, and the film plays perfectly in media player and power dvd, this r the detailson power dvd
    Player Information:
    Player Region Code: Not Specified
    Current Drive: E:
    Title Region Code: Not Available
    Display Information:
    Video Mode: Weave
    Display Mode: DirectDraw
    FourCC Code: YUY2
    Surface Type: Overlay
    Video Attributes:
    Video compression mode: MPEG-1
    TV system: 525/60 (NTSC)
    Aspect Ratio: 4:3
    Display Mode: Both Pan&scan and Letterbox
    Source picture resolution: 352x240 (525/60)
    Frame Rate: 30.00
    Source picture letterboxed: Not letterboxed
    Bitrate: 1.11Mbps
    Audio Attributes:
    Audio Coding mode: MPEG-1 or MPEG-2 without extension bitstream
    Sampling Rate: reserved = 2
    Audio application mode: Not specified
    Number of Audio channels: 2
    Bitrate: 223 Kbps
    Number of Audio streams: 1
    Subpicture Attribute: Not Available
    Hardware Information:
    Processor: AMD Athlon(tm) Processor running at 1199 MHz
    3DNow! Technology: In Use
    Enhanced 3DNow! Technology: In Use
    3DNow! Professional Technology: Not Detected
    IA MMX Technology: In Use
    IA Streaming SIMD Extensions: Not Detected
    IA SSE 2: Not Detected
    Video Accelerator: DirectX VA (not in use)
    Multispeaker Audio Device: Creative SBLive! (not in use)
    SPDIF Output Device: Creative SBLive! (not in use)
    when i try to burn it i get this message
    stream encodind is invalid for a (super) video cd
    invalid audio stream 0Hz ? can anyone help
    thanks
  2. i dont know much about NERO but i reccomend that you use VCD Easy. That is what i use to make VCDs
    A Yellow Submarine
    Did you make this mpeg or did you download it? If you made it, how? We need a bit more information and a topic that describes your problem like "problem burning vcd with nero" would help people that can help you view your topic next time you have a question.
  4. i downloaded it,plays straight from the hard drive on media player and power dvd, but when using nero,and the box comes up saying analyzing file, the bar underneath doesnt seem to creep up like when i do other films?
    Apr 2002
    australia,brisbane
    its probably a divx avi file use G-spot to analyse what type of file it is
