i burned a divx file over using TMPGE and still my easy cd creator claims it wont work. It claims " to make this file cd compliant, i will need to use an mpeg encoder that supports video cd encoding. i thought thats what tmpge would do for me..... i have tried avi and divx files and neither work.....someone please help me as i am running out of hard drive space...what should i do ???????????
where do i choose to go to vcd format...in what menu?....thanks for responding.....
In the bottom right corner of TMPGenc there's thee buttons:
Settings Load Save
1) Click on load
2) Find the VCD template (NTSC or PAL as necessary)
You're not ready to encode using the 'standard' VCD template. Some people like to use other templates or change the standard template to make a xVCD. xVCD doesn't mean better quaility just 'non-standard.' I could raise or lower the quaility (say to get a 120min movie on 1 80min CDR).
Hope this helps. Take a look at the conversion faqs to the left:
http://www.vcdhelp.com/tmpgenc.htm
Another good resource is:
http://www.flexion.org/video/VideoCD/0.html -
i clicked on load but dont know what templates there are...nothing is there......i just tried and chose vcd from the setting button and the only thing that wasnt acceptable in easy cd creator was the frame size... i am sorry but i still just dont get it...i guess im just a dummy...lol
Click Load, make sure you are in the folder you installed TMPGEnc, then click Template. Then choose one that starts with VideoCD.
Vcd audio problems
By Ak_wf1 in forum AudioReplies: 5Last Post: 26th Nov 2011, 20:19 -
Vcd audio problems
By Ak_wf1 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 26th Nov 2011, 19:59 -
Problems with DVD to VCD, including no audio. Help!
By gastrof in forum Newbie / General discussionsReplies: 8Last Post: 4th Jan 2008, 12:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Follow up : audio problems with VCD authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jun 2007, 18:34
