I have a Pioneer A05 burner. Thinking of getting a standalone DVD recorder that only records on +R/+RW media.
Will my -R drive be able to read them? I can't find anything in the specifications that says it does.
Results 1 to 14 of 14
if you have panther the odds increase in your favor.
panther is the only option that offers +r support to a mac.
thus, having panther will increase the chances of your mac being able to support/use the +r media -
I can read +R fine in the A05 connected firewire to my G4 if I'm in 9.2, but the files are greyed out in OS X (10.0 I'm pretty sure..its at work and I can't check now)..I also get "will not play" type message from the PLAYER
The Apple DVD player doesn't pop up automatically (wonder why-maybe cause its in a firewire box?)) but otherwise +R's by FUJI and KHYPER MEDIA (ugh!) have been fine in 9
in the A05 but not in apple's internal DVD-ROM (no disc mounts) -
agreed, an external drive will increase the chances of the disk mounting, but like you said, mounting is only a part of the process.
Panther has been really amazing for me with +r disks. I have been able to mount them, access files and even play them in Apple dvd player.
couldnt dream of this in 10.2
Now to just upgrade to the DVR-106!!!!! -
I installed a Pioneer A106 internally in my G4 and under 10.2 it will write DVD+R/RW discs, but will not read them. My iBook with a Combo drive will read DVD+R discs (also 10.2). Waiting on my free copy of Panther from Apple, so I'm still using Jaguar for the moment. Does anyone know if the DVD+R discs that I have recorded under Jaguar will be any different than if they were burned in Panther?
they should work!
especially since you have the 106 drive.
UPGRADE and enjoy the many benefits of panther
Oh I plan to. I'm just waiting on two things:Originally Posted by galactica
1. ALL of the audio software and hardware that I use to be Panther-compliant (I do audio work professionally, so I can't have the downtime).
2. My Apple rep (I'm a dealer) to send me my free NFR copy of Panther.
I can't wait. Especially for Expose. That is such a cool feature for someone using Logic or any other audio/MIDI app. -
[/quote]Oh I plan to. I'm just waiting on two things:
You could keep Jaguar installed on another disk or partition and start up from it when you need to use the audio apps. Other than ProTools, what apps aaren't Panther ready?
william -
yes, i have jag still on my other HD. i go into it every once and a while still. There are a few things panther has problems with for me.
1. scanner drivers
2. printer drivers
they just dont work. I have generic for printer but its not as good as the real deal. so for my picture perfect prints i go back into jaguar.
id recommend keeping it if you have the ability to -
I've been hearing about a multitude of small incompatabilities even among software that is supposed to be Panther-compliant, including Logic 6.3.1, but the main thing is the hardware drivers, some of which aren't ready yet. As for Digidesign, maybe they'll be ready for Panther by the time OS11 comes out.Originally Posted by willrob
Whenever you install panther, make certain to disconnect FIREWIE drives with OXFORD911 or (especially)922 chipsets..
Os 10.3 has been frying data and rendering chipsets unusable!http://www.macintouch.com/panfirewire.html
Question about either of my Sony drives being able to burn dual layer discs
By Puppets86 in forum DVD RippingReplies: 51Last Post: 9th Jun 2010, 18:04 -
Why don't drives read HD-DVD anymore?
By Sephiroth666 in forum Blu-ray RippingReplies: 40Last Post: 10th Dec 2009, 17:48 -
All Drives Not Recognizing Discs
By Celcius in forum DVD & Blu-ray WritersReplies: 7Last Post: 31st Jul 2008, 15:33 -
Do newer drives rip dual layer discs any faster?
By Sephiroth666 in forum DVD & Blu-ray WritersReplies: 3Last Post: 21st Feb 2008, 09:40 -
DVD drives won't recognize any discs
By TIBGustaf in forum DVD & Blu-ray WritersReplies: 10Last Post: 3rd Jul 2007, 07:29
