  1. Ok heres my problem
    I have authored my vcd movies and menu etc fine through movie factory, Although when i test it in my standlone dvd the movies flickers. I tried it in my ps2 and it works fine no flickering at all, what am i doing wrong before i waste another disc and make it into a coaster
    Cheers
  2. Make certain your FIELD ORDER settings are consistent.
    For example, if I work with files that have the following video/audio properties...
    NTSC drop frame (29.97 fps)
    MPEG files
    24 Bits, 704 x 480, 29.97 fps
    Field Order B
    (DVD-NTSC), 4 : 3
    Video data rate: Variable (Max. 8800 kbps)
    Audio data rate: 256 kbps
    MPEG audio layer 2, 48 KHz, Stereo
    ...then I adjust my Ulead DVD MovieFactory 2 project settings to match.
    To access ADVANCE settings:
    1. I clicked MY COMPUTER;
    2. I clicked my C: drive;
    3. I clicked the DOCUMENTS & SETTINGS folder;
    4. I clicked the ALL USERS folder;
    5. I clicked TOOLS > FOLDER OPTIONS and then clicked the VIEW tab to
    make sure Windows would show HIDDEN FILES AND FOLDERS;
    6. I clicked the APPLICATION DATA folder;
    7. I clicked the ULEAD SYSTEMS folder;
    8. I clicked the ULEAD DVD MOVIEFACTORY folder;
    9. I clicked the 2.01 folder;
    10. I clicked the DVDMF i-n-i file and then typed ADVANCE=1 under the
    [VIODRIVER] heading;
    11. I saved the i-n-i file;
    12. Then I closed Ulead DVD MovieFactory 2 and re-opened the program.
    Now when I enter the project settings, I see a new ADVANCE button under the COMPRESSION tab.
    Clicking this ADVANCE button, I can access many advanced MPEG encoding parameters, including FIELD ORDER parameters.
    Hope this helps,
    Jerry Jones
    http://www.jonesgroup.net
    Originally Posted by Floopy2003
    Ok heres my problem
    Cheers
