Based in UK, I have a bush TV which is NTSC compatible. When playing region free disks in my un-mod PS/2, the picture is B&W. Been told that as long as the TV is NTSC compat should not be a problem. Any ideas?
its not the region that s the problem its the picture i.e you will need a scart cable to play the ntsc movies in colour you can get one from argos for 5pounds hope that helps
Some PAL TVs are indeed NTSC compatible, but need to deliberately be set to NTSC to view the same. Or maybe to auto.
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
Check the SCART socket assignment on the TV, too - I've got a fistful of them on the back of my TV, and only one of them will allow the TV to correctly display NTSC.
sometimes NTSC,you think it is capable,but its just PAL 60.
its not the same,and wont play in color either. -
usually a PAL TV with NTSC capability will only run NTSC through one port, which is usually the RGB Scart.
Convert PAL Region 2 DVD to NTSC Region-Free DVD?
By wizoomer95 in forum Video ConversionReplies: 6Last Post: 6th Aug 2011, 22:10 -
Portable DVD player. Region free. Pal/NTSC
By jtrinc in forum Portable VideoReplies: 2Last Post: 16th Aug 2010, 10:28 -
Does making a dvd player region free also allow PAL to display on NTSC?
By dizmack in forum Newbie / General discussionsReplies: 20Last Post: 25th May 2010, 20:50 -
Region Free/ Ntsc PAL Compatible
By veryconfused in forum DVD & Blu-ray PlayersReplies: 5Last Post: 19th Nov 2009, 19:53 -
Black and white picture on NTSC television from "region free" DVD
By psears in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2008, 14:00
