    Oct 2003
    I have taken a DvD & Decryptyed it(with DvD Decrypter)& then broke it down in to several segments (with dvdshrink) Now I should be able to burn those segments with Nero but its not working out please HELP
    Sep 2003
    Greece
    Hi fzf5bl.
    Can you be a bit more specific about what you have done?
    What do you mean segments??
    DVD Shrink should give you output than can be burned with Nero...
    Maybe you should check out the guides on the left...
    Good luck.
    LeoNapier
    The Truth Is Out There - X Files
    Oct 2003
    This is a training dvd that I would like to eventualy put on a cdr (Using Easyvcd).Anyway I broke this down by chapters and then I backed it up using DvDshink.then I tried to burn with Nero didnt work.so then I thought I would try to burn with DvDdecrypter in iso write when I went to the folder that contained my video_ts file & DvDdecrypter says there is nothing in it.
    Thanks for your help
    Sep 2003
    Greece
    I have PM'd you back!
    Another thing too:
    Easy VCD gives you options to select Programs chains (1 for every VCD unfortunately) so I guess you could split it up that way- One VCD for every episode.
    In case there are too many episodes, you may need to re-author the source DVD so that your preffered number of episodes come up as one PCG and use Easy VCD on that.... ...that's sth you must use advanced tools on though - Decrypter and DVDShrink are novice oriented software and have limited capabilities...
    Start thinking IfoEdit, maybe?
    Hope this helps!
    Leo
