  1. Banned
    Oct 2003
    I am trying to format DVD/CD-RW with Directcd 5 as per the instruction I do a full format which is the only option, enable compression and it formats and verifies forever, to the extent where I can't close it. Anyway the point is this. How do I cut and paste directly onto cd and also read & write from them using Roxio. Direct CD Version 5? It seems to work when it wants. Thanks
  2. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    My 2Cents says ROXIO DIRECT CD is evil technology
    Get a burning program
    or use DLA from VERITAS please!
  3. Banned
    Oct 2003
    Thanks very much.
    I will CERTAINLY do away with Roxio Direct CD/Easy Creator cos all I wanted to do was to store and download my data/multimedia onto disc and not have them converted into read only files. Also most definitely I'll have a look at DLA VERITAS or other softwares if there are any more.
  4. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    You must be using 98, 2000, or millenium because they fixed that
    if you're running WINDOWS XP
    this is auto matic.. Meaning ..If you burn a WRITEABLE file to CD-R and copy it back to the hard drive from there, it retains WRITEABLE status
