Hello, I have a Divx file 640*272 mpeg4 716.110kb 91.58 min codec Div3 my problem is that when I view the file it gets to certain spots then freezes and a message comes up saying that this program has detected a problem and will shut down it doesnt matter which program I use the same thing happens. I scaned for bad frames with virtualdub same thing happened, and again with Tmpenc. Will I have to scrap this file and start again or is there somthing I can do. P.S If I skip these bad spots the file runs perfectly till it gets to the next, there are 5 bad spots.
Thanks![]()
If you know where they are then edit them out with Vdub. Look in the Guides section for directions.
Virtual Dub 1st & 2nd Pass Encoding
By OrchestraAndChoir in forum Video ConversionReplies: 10Last Post: 22nd Jul 2012, 08:20 -
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 14:24 -
Working with Subtitles on a 64-Bit System: XVid, SUPER, & Virtual Dub
By jdanniel in forum SubtitleReplies: 17Last Post: 22nd May 2010, 14:08 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 04:46 -
Ripping DVD & Virtual Dub Problem...
By Chana1 in forum DVD RippingReplies: 7Last Post: 8th Jun 2007, 08:45
