Ok, I made a VCD iso, with VCDEasy (freeware version), and that seemed to work fine. I wasn't sure how to burn with VCDEasy (if even possible), so i made the ISO and Burned it with Alcohol 120%.
Earlier i had a problem making a vcd with nero, that caused skipping near the end of the last track. I was told on a previous topic to try VCDEasy, maybe i didn't burn it right, but i could only make an ISO so i burned it with Alcohol 120%. I again got the same problem with skipping.
Any suggestions, and BTW, what is this this ASPI thing in VCDEasy, my only option is NERO.
I had an SVCD from VCDEasy that played up at the end of the disc. Thought it was the NERO burn that went wrong but I went back and played the VCDEasy image file in PowerDVD and it was bad also.
I redid the VCDeasy image and it was fine the 2nd time.
I always burn the VCDeasy image using NERO.
ASPI,
I'm not sure if this has anything to do with your question but one thing I and others have had to do is place a copy of the WNASPI32.DLL file, from the NERO folder, and stick it in the c:\Windows\system32 folder
Vegas 11, multicamera track only rendering to one video track
By CursedLemon in forum EditingReplies: 0Last Post: 29th Feb 2012, 03:11 -
need to equalize volume of a single track made by appending 3 track
By perfection in forum AudioReplies: 2Last Post: 23rd May 2011, 02:57 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 12:25 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 12:16 -
re-encode only video track of Quicktimes but keep audio track untouched
By brennbaer in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2007, 08:25
